vcProcessFlowTable
The process flow table holds the sequences of processes that each product belonging to a certain flow group shall follow as it travels in the simulation.
Referenced by: vcProcessController.FlowTable
SequencesvcObservableListRGets the list of process sequences in this process flow table.
copySequenceFromvcProcessSequencevcProcessFlowGroup sourgeGroup,
vcProcessFlowGroup targetGroup
Copies the process sequence from the given flow group.
sourceGroup (vcProcessFlowGroup): A flow group to copy the sequence from.
targetGroup (vcProcessFlowGroup): A flow group for which to create the new sequence.
RuntimeError: When the source flow group has no sequence.
RuntimeError: When the target flow group already has a sequence.
vcProcessSequence: A new process sequence.
createSequencevcProcessSequencevcProcessFlowGroup flowGroupCreates a new process sequence.
flowGroup (vcProcessFlowGroup): Flow group for which to create a new process sequence.
RuntimeError: When a sequence for the given flow group already exists.
vcProcessSequence: The newly created process sequence.
getSequencevcProcessSequencevcProcessFlowGroup flowGroupGets the process sequence associated to the given flow group.
flowGroup (vcProcessFlowGroup): Process flow group.
vcProcessSequence: A process sequence. None, if the flow group does not have a sequence.
